Revit Architecture
srameshburndy
Message 1 of 6 (9,450 Views)
What is Shared Parameters and how to use it?
9450 Views, 5 Replies
04-10-2013 05:30 AM
Could anyone explain what is shared parameter?
How to create that .txt file using in shared parameter
Kindly explain with images
CADastrophe
Message 2 of 6 (9,439 Views)
Re: What is Shared Parameters and how to use it?
04-10-2013 05:39 AM in reply to: srameshburndy
Have you taken a look through WikiHelp? Follow this link - WikiHelp: Shared Parameters
It should help quite a lot. If you hit any snags or have any confusion, just let us know.
Alfredo_Medina
Message 3 of 6 (9,428 Views)
04-10-2013 06:09 AM in reply to: CADastrophe
The shared parameters file is like a bridge to pass data as parameters, between multiple families or projects, data that can be displayed in tags, and listed in schedules.
To beging creating your shared parameters file, use Manage > Projects > Shared parameters, and use the Create button.
For all the detailed info, refer to the Wikipedia article listed above. I hope this image helps:
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Contributor
bimandict
Message 4 of 6 (9,377 Views)
04-11-2013 04:26 AM in reply to: srameshburndy
If you are new to shared Parameters (SP) it can be hard to get your head around it theoretically.
I suggest you make set up a test environment with a copy of your standard template and a copy of the SP file you are pointing Revit to. Point your test template to the test SP.
The start to create simple families e..g a cube with SP for width and height (for flexing the cube) for example.
Then find these SP you used in the SP settings in Revit (manage/shared parameters see image) to get an understanding of where the SP is coming from when you change the properties of the width and height of the cube once placed in a project.
Also look at the SP txt file to find the width and height just to visually confirm the relationship it has with Revit.
Analyze a standard door. Create a door schedule and back track the SP on everything you decide to schedule.
I would suggest that you stick to the default Autodesk SP file in the beginning until you are sure of what your office requires and how to create new SP that will make sense and work in the long run.
Get your hands dirty.
Jimi Clarke
BIM Manager - London
Microsoft Cloud Services Partner
constantin.stroescu
Message 5 of 6 (9,335 Views)
04-13-2013 11:18 AM in reply to: srameshburndy
All  the people that answered to  your question here are right.....
I'll show you an example that I made for an young architect in order to understand what is shared parameter good for.
Suppose you want to make a piese of furniture ( call it box), then you need to insert it into your project and there to make a schedule which controls not only the number of furniture pieces (as the Type and Instance allow ) but also their dimensions , areas per unit and per total, volume....If you want this you have to use Shared Parameters.
  • Let"s make first,  a Furniture Family...a simple box with three parameters: WidthS ,DepthS and HeigthS -(like in image 010),  check Shared from Parameter Type - click Select
  • Edit Shared Parameter >Shared Parameter File> Create >Save in> save the Text file into a location in your computer under a suggestive name - image 02
  • Then from Edit Shared Parameters >Groups>New... call it Box shared parameters...and OK...image 03
  • from Edit Shared Parameters >Parameters >New.. create a series of length parameters...width, depth and height....image 04 and 05
  • Then, create the object, the Box ( all the constraint were applicated to the reference planes before and the box sides are attached to the reference planes) - image 06
  • then, load the family object (the Box) into the project
  • In Project ,  made a Furniture Schedule ....the Box object will appear in the schedule...but it can be seen in Fields>Avalable Fields some new fields : the shared- WidthS , DepthS and Heights....image 07 ....ad these to the schedule - image 08
  • Now in the schedule I can create other Calculated Parameters as Area or Volume....for instance the total upper surface of the boxes or the total volume of them....image 09 and 10
  • These parameters can now used for other objects that you want to appear in schedules
Constantin Stroescu
BIM Manager AGD
srameshburndy
Message 6 of 6 (9,291 Views)
04-16-2013 09:13 AM in reply to: constantin.stroescu
Thanks for your detailed explanation.its working
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
