If any element in my model has a warning associated to it, and I try to review it, the warning dialog will not open. How can I solve that?
Thanks in advance
Do you have the latest Update installed (Update Release 3 for Revit Architecture 2013)? If you have had Microsoft .NET Framework updated to 4.5, that causes issues with the contextual ribbons in Revit 2013. Update Release 3 should resolve those issues.
Thanks for the reply.
I updated to release 3 and unfortunately I keep having the same problem.
I am using windows 8 pro 64bits and .NET Framework 4.5.
I had problems in ribbon before but I solved them when update revit with release 2.
Are you using multiple monitors? Or were you previously using two monitors, and have now switched to a single monitor?
