Walls drawing tools
2 REPLIES 2
392 Views, 2 Replies
Walls drawing tools
Just loaded the latest version of REVIT 2013 and noticed that the drawing tools box does not come up when you select "walls"??
Has this been changed?? Anybody know?
Grumpygoldie
2 REPLIES 2
AJA14
No, the contextual walls tab should show up with the wall drawing tools. Try Repairing or reinstalling.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
loboarch
You need to make sure you have installed the upadte to Revit 2013.  What you are describing sounds a bit like an incompatibility with .NET 4.5 and Revit which causes contextural tabs to not display correctly.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
