Revit Architecture
Active Contributor
hakuna78
Message 1 of 11 (3,264 Views)
Walls are not visible in floor plan
3264 Views, 10 Replies
09-14-2006 06:43 PM
I don't know what changes I made to the settings- now when I draw walls on the floor plan Revit displays a message "None of the created elements are visible in Floor Plan: Level 2 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
I checked the Visibility/Graphic overrides, and the visibility of walls is on. Also I checked the floor plan property, still the visibility of walls is on. How to solve this problem? Can somebody help? Thanks a lot.
*C Ryan
Message 2 of 11 (3,263 Views)
Re: Walls are not visible in floor plan
09-14-2006 07:20 PM in reply to: hakuna78
i've had this happen before when drawing soffit walls. the base offset of
the wall was above my cut plane. when you draw the wall click on properties
and check the settings.
wrote in message news:5330097@discussion.autodesk.com...
their settings."
*Architectural Staff
Message 3 of 11 (3,262 Views)
09-21-2006 07:25 AM in reply to: hakuna78
If you have worksets enabled you might be drawing the walls in a workset
that is turned off.
Robert Witte
> their settings."
Valued Contributor
David Wills
Message 4 of 11 (3,262 Views)
09-22-2006 06:23 PM in reply to: hakuna78
1. Check your View Range settings.
2. Check the Base Constraint Level and Base Offset values in the Wall properties as they may be above the Cut Plane.
3. There is a possibily that the values of the Base Constraint and Base Offset are BELOW the current View Range.
4. The Wall type may be set to Foundation which uses Depth instead of Height and the Walls are below the View Range.
Anyway you cut it, I'd bet London to a brick it's a View Range issue.
DW
New Member
K.Reynolds
Message 5 of 11 (3,262 Views)
10-18-2007 07:12 AM in reply to: hakuna78
I've just come across the same problem. No matter what view range I use the walls just don't show. I draw new walls, they don't show.
The work around I used:
Create a new level near the old level that is not showing up.
Relate all walls that were related to the old level, to the new level.
Delete old level.
There must be a bug in the program because I could find no reason why my walls weren't showing up. View settings, View Range, ect. Nothing worked but this.
Cheers!
*Brian
Message 6 of 11 (3,262 Views)
10-19-2007 04:46 AM in reply to: hakuna78
not knowing anything about your model we would just be stabbing in the dark
here.
are the walls non-bearing and your view is set to structural?
are the walls on a workset that is not visible in the view?
is the wall category hidden - are you using 2008?
Brian Earsley
www.arete3.com
18645 West Creek Drive
Tinley Park, Il 60477
708.342.1250 x.225
wrote in message news:5753598@discussion.autodesk.com...
Delete old level.
this.
Cheers!
Active Contributor
rendermaster
Message 7 of 11 (2,431 Views)
01-02-2013 02:58 PM in reply to: hakuna78
-go to properties and check Discipline, you might using another discipline it might be on structural... make it architectural
Valued Contributor
Irish2
Message 8 of 11 (2,422 Views)
01-02-2013 04:37 PM in reply to: rendermaster
And your response is almost 6 1/2 years after the original question.  ???
New Member
mohamed.el.nagar
Message 9 of 11 (1,528 Views)
09-15-2013 06:48 AM in reply to: Irish2
Iam modeling a cold form steel building using PrescientDesign. and i couldn't draw any wall because of this message
"None of the created elements are visible in Structural Plan: Level 2 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings."
New Member
norraep
Message 10 of 11 (611 Views)
04-07-2014 03:32 PM in reply to: rendermaster
OMG... I had same issue: And that was he answer I was looking for. Thank you!
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
