I'm having trouble with a wrapping detail at a window reveal.
The problem is that I cannot get the plaster and render layer to stop against my window frame. It
overlaps it.
I've attached a PDF of the detail I'm trying to achieve, and a Revit file of what I'm ABLE to achieve.
Any help would be appreciated.
I think it is not possible to make it exactly as in your .pdf with just closure planes and wraps activated, because the finish layers need to wrap beyond the plane where the frame of the window and the masonry meet, and with their inner faces aligned. See if this solution works for you (closure plane + symbolic lines in window family). (See attached image and .rvt)
