Revit Architecture
abir.acharjee
Message 1 of 3 (227 Views)
Wall wraping material
227 Views, 2 Replies
06-30-2012 06:26 AM
Here we have created a simple mass (image 1) and made walls from the faces (image2). After joining the faces and giving a "wrap around both" material, the brick metrial is not continuous. There is a band of different material seen.
How can we get the brick to run with no band inbetween.
Valued Contributor
vector3
Message 2 of 3 (206 Views)
Re: Wall wraping material
06-30-2012 03:27 PM in reply to: abir.acharjee
Well I guess you are talking about the way two walls intersect, or join.
The first thing I would do is hit the "Edit Wall Joins" tool.
Alfredo_Medina
Message 3 of 3 (188 Views)
07-01-2012 05:22 AM in reply to: abir.acharjee
Edit Wall Join won't work for these slanted joints. The "wrap" setting of the wall type won't help for these joints either. Simply make all the walls with Location line = Finish face: Exterior.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
