Wall sweep doesn't adjust automatically according to wall profile?
2 REPLIES 2
436 Views, 2 Replies
I just created a wall sweep on a wall , but I noticed the sweep doesn't adjust to the wall profile, please see the second floor wall in the attached image. Is there anyway to make the sweep adjust to the profile of the wall automatically?
2 REPLIES 2
LisaDrago
You may want to consider a different tool for this... It looks like you want it to follow along the roof line.
You may want to try a roof fascia a try.
If this is not what you are looking for - may be little more info would help.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Intecinfocom
you can also try to check 'lock' function
