Revit Architecture
Member
ryhane
Message 1 of 5 (710 Views)
Accepted Solution
Wall room bounding properties are not maintained
710 Views, 4 Replies
12-15-2010 09:14 AM
I have a restroom where the toilets are housed in separate "rooms" divided by full height/full thickness walls.  I want the restroom to be scheduled including the area of all of the smaller rooms so I unchecked the wall's room bounding property.  However, every time I reopen the project, this property, although unchecked, is back in effect.  How can I get the room bounding property (when unchecked) remain the same when I reopen the file from day to day?  I made a simpler file to test this, but could not produce the same error.
Employee
ryan.duell
Message 2 of 5 (684 Views)
Re: Wall room bounding properties are not maintained
12-16-2010 01:27 PM in reply to: ryhane
By default the room bounding property of a wall should stick whether checked or un-checked when the file is opened and closed.  I could not reproduce the behavior in some series of testing.
Does this happen on a few walls or every wall with this layout?  I would test the following to see if we can modify this behavior:
1.  Cut & Paste the walls to the same place, verify room bounding is un-checked.  Save and close the project, verify if it remains un-checked on open.
2.  Delete one of the walls this is occurring to, and draw a new wall from scratch of the same type [do not copy or create similar].  Un-check room bounding, save and close file.  Reopen to verify if the same issue occurs.
Please let us know if this was helpful in resolving the issue.  Thank you,
Ryan Duell
Autodesk, Inc.
Revit Clinic
@revitclinic
Member
ryhane
Message 3 of 5 (643 Views)
12-21-2010 07:29 AM in reply to: ryhane
Thanks Ryan,
Copying and pasting the walls again seems to have fixed the problem, even after a few days of continued use/editing.  Thanks.
Kindly,
Ryan Haney
New Member
zoltan_w
Message 4 of 5 (220 Views)
09-13-2013 12:27 PM in reply to: ryan.duell
This is a huge ongoing problem because room bounding is a very prowerful tool. I am using Revit 2013, and this posting was from 2010.  This problem still persists.  Does Autodesk actually recognise these problems or are we waisting our time as I am waisting my time using Revit to draft my projects?
*Expert Elite*
rosskirby
Message 5 of 5 (204 Views)
09-13-2013 07:01 PM in reply to: zoltan_w
To be fair, it's a very minor problem that only occurs rarely, if at all.  I've been using Revit for 6 releases, and have never once encountered the problem, and after testing it in 2012, 2013, and 2014, I was unable to reproduce the issue.  Sometimes modeling errors, whether you're aware of them or not, are the root cause of the problem, not the software.
Ross Kirby
BIM Manager
Arcturis
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
