Revit Architecture
Distinguished Contributor
elina.hyvamaki
Message 1 of 3 (344 Views)
Wall roof joint
344 Views, 2 Replies
09-21-2013 03:01 AM
I've attached a picture of a wall roof joint, where I would like the concrete core of the roof to meet the concrete core of the wall. I know I could do this view-specifically by "Cut Profile" tool. However, my question is: Is there any way to do this in actual 3D? So that the joint would look the same also in other sections?
*Expert Elite*
Alfredo_Medina
Message 2 of 3 (324 Views)
Re: Wall roof joint
09-21-2013 06:21 AM in reply to: elina.hyvamaki
If the materials are the same, they join by simply using "Join Geometry". Even if it is floor to wall, or roof to wall, they join.
If that does not give you exactly what you need, you might considering using "parts" or, as a last resource, creating the components of roof, floor, or wall as individual elements.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
elina.hyvamaki
Message 3 of 3 (266 Views)
Re: Wall roof joint
09-22-2013 04:53 AM in reply to: elina.hyvamaki
Thanks for your answer! It's great to know about the "Parts" tool, because I can use that, if "Join Geometry" doesn't work. I did try the "Join Geometry" tool before posting my question, but it seems like a window interferes with the joint, so that it doesn't do it right, if the window is not situated higher than the roof slab. In the file attached, the joint on the left side is correct, but the ones on the left are incorrect.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
