Wall, attach top
2 REPLIES 2
aalonsojaver
433 Views, 2 Replies
Wall, attach top
Exist a way to Attach the top of the wall in a element that is not a floor or roof.
I have a wall under a stair and i want to make de top of the with a slope.
thanks!!!
2 REPLIES 2
Hi
Attach the wall with stairs allowing you to do that, but you can use the following method.
1 - Plan View Ref Plan and draw a name to your propertise window.
2 - Select the Component Model-In place and Wall Options window, choose a name and press Ok to enter your family.
3 - Ref Plane to a Set Voied Extrusion method and depth to draw Profile.
4 - Now, Profile, Cut drawn from Wall least now.
I hope to help you
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Rail Community
