Wall and floor connection/cut
11 REPLIES 11
Message 1 of 12
m.zygaitis
2350 Views, 11 Replies
I am working with revit for a long time and recently an issue appeared. I was working with mass, then attached walls by face, divided mass into floors, made them. In a section view my wall is with angle to background. I want to connect wall to floor so that none of the floor would be visible outside. I add an image. I was trying to work with cut profile, but it doesn't eliminate all of the problem. I use revit 2012.
Thank you in advance.
Tags (3)
11 REPLIES 11
Message 2 of 12
in reply to: m.zygaitis
In-place floor.
Message 3 of 12
m.zygaitis
Could you be more specific? i didn't find and don't know how to do it.
could you, please, explain?
Thank you.
Message 4 of 12
Extrude the floor off of a work plane. Select floor category for it.
Message 5 of 12
m.zygaitis
As i understand, you made section profile of the floor and horizontally extruded. At this point i can not make vertical shafts, is it because you have to vertically extrude floors?; also i can not edit structure of the floor, am i supposed to drow it with region?
thak you.
Message 6 of 12
That's an elevation view of the floor and walls. To make an in-place
floor, draw a reference plane in a level view and give it a name in its
properties. Then go to an elevation view that would be perpendicular
to that plane. Then hit your model in-place command and the first thing
it wants to know is what is this thing you want to build, (category), select
floors. Then hit the extrusion button and it will ask you to select that
plane you just made so it knows what to extrude from. After you finish
this floor you can pull it into different lengths with the grips.
BTW you can't manipulate system floors in strange ways, so you have
to delete them and build in-place floors.
And if you want to make floors that are twisted in really strange shapes,
you will need to learn more about in-place families. In that case it might
be easier to start them in the mass editor.
Message 7 of 12
m.zygaitis
Still I don't understand if in place floors can be structurally edited - different layers added? And is in place floor being cut with shaft function? The questions are because I didn't manage to to it and I am wondering if it's not possible o I did not find how to.
Thanks.
Message 8 of 12
You can't edit assembly layers for floors
like you can with walls, unless there is
something in the new Revit I haven't seen
yet. But we are not talking about system
floors anyway, we are making fully custom
in-place floors. That means we make every
part of that floor manually. See the image.
Message 9 of 12
m.zygaitis
Well still the same problems. Should I make a shaft through the modeled floors manually one by one? Also how did you managed to get few layers for the floor? Did you draw several floors in order to get the result?
Thanks.
Message 10 of 12
"layers for the floor?"
Each part of the floor is a separate in-place family.
As they would be in reality.
"shaft through the modeled floors manually one by one?"
Yes every part is created separately.
See the image.
Message 11 of 12
m.zygaitis
Thank you. huge help.
Message 12 of 12
Any part of that in-place floor you want to change
you just click on it and then hit "edit in-place". You
can poke holes in it with voids, stretch it, pull it,
change the shape of it, change its materials, change
the way it shows in any kind of view and just about
anything else you can imagine.
