Revit Architecture
themelis_d_m
Message 1 of 5 (1,051 Views)
Wall and Beam join error
1051 Views, 4 Replies
02-07-2011 04:24 AM
Hi again,
i have a 20 cm brick wall with 10 cm insulation on the outer side and a 25 cm concrete beam as you can see in the first attachment, which i 'd like to join. However this is not possible and i get the second attachment's error.
Why is this? It's not the same width with the wall...
Thanks in advnace,
Michalis
Employee
ryan.duell
Message 2 of 5 (1,009 Views)
Re: Wall and Beam join error
02-08-2011 07:38 AM in reply to: themelis_d_m
Typically you would only receive this message if you are attempting to use join geometry between 2 elements, where one is smaller or there are 2 elements in exactly the same place.  Are you able to verify:
1.  If the element you are joining will completely be absorbed by the larger element?
2.  Are there 2 elements directly in the same place causing this message [for example 2 larger walls or 2 of these smaller wall segments]?
Thank you,
Ryan Duell
Revit Clinic
@revitclinic
themelis_d_m
Message 3 of 5 (1,007 Views)
02-08-2011 08:01 AM in reply to: themelis_d_m
Hi Ryan,
The beam is 25 cm wide. The wall is 30 cm wide(20 cm brick and 10 cm insulation on the outer side). The result that i wanted to achieve is to join the beam with the bricks.
Insulation continues up to the floor, like the example i attach (which is made with the cut profile tool)
Thanks for your time, once more
Michalis Themelis
Employee
ryan.duell
Message 4 of 5 (919 Views)
02-18-2011 01:07 PM in reply to: themelis_d_m
This may not be expected.  Is the issue reproducible if you copy these elements to a blank file and attempt the same?  If so can you attach a simply example to this thread?
Thanks again,
Ryan Duell
Revit Clinic
@revitclinic
themelis_d_m
Message 5 of 5 (851 Views)
02-24-2011 11:30 AM in reply to: ryan.duell
Hi again and sorry for the delay,
i have tried to attach a portion of the drawing so that you can try join/unjoin the beams and the walls in the section views but unfortunately it can be sent... (don't know why.. it's a small rvt file..)
Is there an email that i can send it to?
thanks in advance,
Michalis Themelis
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
