This is how I would do it.
If you are using Host Sweep>Wall Sweep from the Modeling bar,
Settings>Object Styles - at the bottom right of the dialog under
"Modify Subcategories" click New.
Enter your name and make it a subcategory of Walls
In your plan view go to your Visibility/Graphic Overrides. Scroll down
to walls, click the plus sign and turn off the subcategory you just created.
Then change the subcategory of the wall sweep to be that of the
subcategory you created.
Chris Kendall wrote:
> Just a quick question.
> How can you turn the wall sweep off so it doesnt show in plan view. I cant
> find anywhere that controlls it in th visual graphics. I would like to be
> able to do this without changing the cut plane.
> Thanks Chris
