Wall Sweep
6 REPLIES 6
BIMAbhi
1934 Views, 6 Replies
Wall Sweep
Can we turn off the wall sweep in plan view in revit? We have attached a jpg for your help.
Thanks & Regards
BIMAbhi
6 REPLIES 6
VWD-MLM
in reply to: BIMAbhi
One thing you could do is to raise the "Bottom" offset of the Primary Range settings in the View Range to slightly abovr the top of the sweep.
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
BIMAbhi
We use this wall sweep as skirting of a wall and it was placed at the bottom of the wall. In this case we uses the default view range setting of revit. We have attached the jpg of the view range setting. Can we change this with visibility graphics? If possible then please suggest us.
Thanks & Regards
BIMAbhi
VWD-MLM
In the View Range DB, Under "primaryP, try raising the BOTTOM from 0.0000 to something just above the top of the sweep.
Michael L. Maloney
BDSU 2015, 2016
BIMAbhi
Thank you for the suggestion, but for a typical architectural plan we have to show everything like flooring, door swing, etc including the skirting. We just want to hide the skirting in particular details. By following your suggestion, the flooring is getting hidden as well. Kindly review and suggest.
Thanks & Regards
BIMAbhi
Dave_Jones_DDP
can you not right click on the sweeps and select Hide In View/Elements?
Dave Jones - DDP
BIMAbhi
in reply to: Dave_Jones_DDP
We have created this wall sweep with sweep option in wall properties DB. So we can not hide the element.
Thanks & Regards
BIMAbhi
