Can we turn off the wall sweep in plan view in revit? We have attached a jpg for your help.
One thing you could do is to raise the "Bottom" offset of the Primary Range settings in the View Range to slightly abovr the top of the sweep.
We use this wall sweep as skirting of a wall and it was placed at the bottom of the wall. In this case we uses the default view range setting of revit. We have attached the jpg of the view range setting. Can we change this with visibility graphics? If possible then please suggest us.
In the View Range DB, Under "primaryP, try raising the BOTTOM from 0.0000 to something just above the top of the sweep.
Thank you for the suggestion, but for a typical architectural plan we have to show everything like flooring, door swing, etc including the skirting. We just want to hide the skirting in particular details. By following your suggestion, the flooring is getting hidden as well. Kindly review and suggest.
can you not right click on the sweeps and select Hide In View/Elements?
We have created this wall sweep with sweep option in wall properties DB. So we can not hide the element.
