Revit Architecture
Active Contributor
Message 1 of 4 (1,012 Views)
Wall Sweep to Follow Wall Profile
1012 Views, 3 Replies
04-12-2012 01:17 PM
Hello All,
I was wondering if there is a way to get a wall sweep that's set up in the type/structure properties to follow a wall if that walls profile has changed.  For example, in the image below, I've split the wall and adjusted it's profile to create some cheesy angled parapet.  How do i get my wall cap to follow along?  I thought splitting it and changing it's height would work, but no.  And if I change the profile without splitting the wall the wall cap just runs right through the wall, as if the profiel was never even changed.  I have no idea how to do this and any help would be greatly appreciated.
~Wes~
Message 2 of 4 (1,011 Views)
Re: Wall Sweep to Follow Wall Profile
04-12-2012 01:21 PM in reply to: oihadsf
You can't use a built-in sweep on a Profile Edited wall.
You can use an in-place family, or a Roof by Extrusion as an alternative method.
You might also try using a Line-Based Family, with a loaded Profile.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Active Contributor
Message 3 of 4 (1,007 Views)
04-12-2012 01:25 PM in reply to: ccollins
Cliff,
Thanks for the quick response.  I was afraid that would be the answer.  I'll look into the other options you've posted and give them a try.
~Wes~
Valued Contributor
Message 4 of 4 (902 Views)
05-09-2012 03:24 PM in reply to: oihadsf
In-place families work really well for this situation.  I think The Revit Kid had a different method on his blog using reference planes, but in-place families are super easy.  Only advantage to his method was the sweep actually changed when the reference plane changed, but its a lot of work and I never got it to work successfully myself.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
