You can get rid of the error message if you follow the rule that says that two unlocked layers must be adjacent, either at the top or the bottom.
So, you can have Locked-Unlocked-Unlocked , or Unlocked-Unlocked-Locked. You can also have Locked-Unlocked-Locked. If all 3 are unlocked, you won't get any error messages, but the wall won't do anything. The 3 options mentioned before will let you work. However, notice in the illustration provided that, out of 3 components, 2 of them must align. It is not possible to move them all independently without at least 2 of them being in alignment. To obtain full freedom of moving all the three layers independently from the other one, you need to create a separate very thin "finish" wall type.
Alfredo Medina
info@planta1.com
http://www.planta1.com
Online Revit Training
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
