Before i start, I'm not questioning why Revit behaves like this I'm just trying to understand how I can stop the behaviour happening.
Hopefully a short video is attached showing the issue.
I have two walls which I have split in section. The right hand one is split at the height of Level 1 the left hand one is split at an arbitrary point.
If I now select the lower wall element in the left hand wall and drag the top of it down the wall above remains attached. Unlocking the wall, profile or attempting to unjoin the walls has no effect. If I move one of the walls horizontally away from the other the top and bottom are still joined / linked.
However the right hand wall which was split at level 1 does not exhibit this behaviour.
I can see benefits in how the left hand wall operates however I can also see how, as a project develops this behaviour could lead to unexpected results.
My only 'sensible' work around to stop this happening (ie the walls remaining stuck together) is to copy one of the elements, delete it and then paste it in place.
I can find no other way of making Revit behave in this way (like I say this behaviour could be useful) other than by splitting at wall.
Can anyone add any clarity to this behaviour?
Cheers
K.
Solved by constantin.stroescu. Go to Solution.
Looking at your recording:
https://chronicle.autodesk.com/main/details/6367c91f-a815-4fd2-9445-53e3c8ec5991
Constantin Stroescu
