Materials made walls, floors, etc. disappear so I followed instructs to cleanse %temp% with no luck. So Materials were probably corrupt ( somehow..) so they were sequentially uninstalled as described. Went to use the shown links in another article here to reupload and whammy "Page requested was not found". Oh, no now without materials...
Does anyone know the correct links to find and download the ILL base image, CM protein materials, and ILM Medium image material libraries?
These links do not exist: autodesk/support/ADSK Materials/ CM/ Protein Materials.msi
autodesk/support/ADSK Materials/ ILL / Base Image library.msi
autodesk/support/ADSK Materials/ ILM/ medium image library.msi
I would greatly appreciate getting my little Revit back!
Thank you, CRH
Hello there great masters of Revit. I await your response on this one.
I could use some help from anyone who knows where in the jungle to find these.
Chad Raymond Hines
RA, NCARB, CGVisualist
Hi.
Check this.
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Rendering-Issue/td-p/2921384
