Revit Architecture
Valued Contributor
kwihae
Message 1 of 2 (740 Views)
Voids to cut host wall in window family
740 Views, 1 Replies
02-16-2012 07:46 AM
I would like to cut a void into the wall of a host window family.
When I place a void in the family, it does not cut thought the wall.
I tried making the void on a plane perpendicular and parallel to the wall plane.  I dont know if this has anything to do with how voids work.  But its not working.
I also dont have an 'opening' element in the window family.
help!
Message 2 of 2 (737 Views)
Re: Voids to cut host wall in window family
02-16-2012 08:10 AM in reply to: kwihae
Inside the project, try using Cut Geometry--select the wall, then the window family.
Does this work?
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
