Visulize fabric sheet in section
3 REPLIES 3
pevelor
311 Views, 3 Replies
Hi
I am unable to visulize the projection line of fabric sheet in section view. However, the cut lines are visiual.
Any thoughts how I can make them visiable?
3 REPLIES 3
AJA14
in reply to: pevelor
Hi. Change your detail level to Fine and your visual style to Hidden. That should do the trick.
If this solves your problem please Accept As Solution.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
pevelor
in reply to: AJA14
I am using both fine and hidden in the picture included earlier ( I guess I shoould have mentioned that)
Any other suggestions?
AJA14
Hi. I can't really say what is happening unless I see the model. Try attaching it so that I can take a look.
Just a suggestion, make sure that your fabric reinforcement is existing and is passing through your section in the parallel direction.
Ali Al-Hammoud
