Hi, I was starting to define some floor materials in my project, so i decided to start using the surface patterns of revit to show the different kind of floors of my building. In levels 1 to 3, the graphics are fine, but in my level 0 i keep seeing the surface patterns of the level above (level 1). I've checked several times the view range, but it doesn't seem to be a problem there, as i've used the same principles of visualisation. Does anybody know if there could be something i'm missing which is causing this visualisation problem?
L A0 is at 0.00m height, and the next level, level L A1 is at 3.00m height
Thank you very much
