Revit Architecture
Valued Contributor
RudyBeuc
Message 1 of 3 (974 Views)
Viewbreaks, viewports & Sheets
974 Views, 2 Replies
02-10-2012 09:19 AM
So I've created this wall section and used viewbreaks to break the crop regios up so i can fit the final view on a sheet.
The problem is, when I place the broken up section on a sheet, the viewport does not break up like the view region. Pease see the attached file, Screenshot..
My question is? How do i break up the viewport on the sheet so I can squeeze the visable regions together?
Rudy Beuc
Employee
loboarch
Message 2 of 3 (961 Views)
Re: Viewbreaks, viewports & Sheets
02-10-2012 10:37 AM in reply to: RudyBeuc
I think you are missing one step after using the view break controls.  The view break will cut out a portion of the view but the pieces that remain are do not get moved closer to one another.
Once the view is broken there is a little arrow inside the crop region of the remaining parts.  it is sometimes hard to see because drawing elements obscure it.  You can use this arrow to move the portions of the view closer to gether so whn placed onto a sheet it will fit.
You can find more information on this process at the resizing crop regions page of the wikihelp.  The part that specifically mentions this is near the bottom of this page.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Valued Contributor
RudyBeuc
Message 3 of 3 (953 Views)
02-10-2012 12:53 PM in reply to: loboarch
Thanks, that did the trick. I do wish however that this break crop region functionality was available in two directions simultaneously.
Rudy Beuc
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
