I have a project where the floor plan is broken into area A and B. I am using a parent and dependant views to accomplish this. I have notice (or rather the client has noticed) that some of the back references are pointing to the wrong dependant view. For example, if an enlarged plan is placed in Area B on sheet A-102, when I go tot he sheet where the enlarged plan is located, the back reference is pointing to Area A on A-101 not A-102. I have tried recreating the view both in the view and by activating the view on the sheet and creating the enlarged plan with nothing. See attached. It does not happen with all views only certain type. Am I missing something here or is this a glitch?
Please see the linked under this search as I believe you will find your answer:
Thanks for posting.
