Revit Architecture
Active Contributor
rlabib
Message 1 of 2 (245 Views)
View template won't work in legend views
245 Views, 1 Replies
03-05-2013 08:36 AM
I applied 7 filters to my project to distinguidh between all 7 types of walls used within the project. then I created a view template that has all 7 filters to override walls pattern I applied the view template to my 2 floor plans and I put both plans in one sheet , then I needed to add a wall legend to add to the sheet , so I started adding all 7 walls to the legend and then I applied the same view template , but the view template didn't work in the legend ( wall patterns won't show ).
Any ideas .
Alfredo_Medina
Message 2 of 2 (211 Views)
Re: View template won't work in legend views
03-05-2013 08:20 PM in reply to: rlabib
Yes, the view template settings that you applied for the walls in a model view will not work on the Legend. I assume it is because the legend is not really a model view.
Other ideas I've seen about a legend for wall types include:
  • using a Revit link with all the wall types,
  • creating the sample wall types in a layer that happens before the Existing phase.
There might be other threads describing these methods in more detail.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
