I have adjusted my North Elevation (using View Graphics) exactly the way I’d like it to look in elevation, and would now like to apply those same visibility adjustments to my other elevations. Is there a way I can save that view as a template and apply to other elevations, or do I instead need to create a view template, make all the adjustments to that template, then apply the template to the elevations?
Solved by tonkata. Go to Solution.
Good to hear!
LD
We moved your reply to its own topic in the Autodesk Revit Architecture forum.
