View Templates
3 REPLIES 3
tonkata
538 Views, 3 Replies
View Templates
I have adjusted my North Elevation (using View Graphics) exactly the way I’d like it to look in elevation, and would now like to apply those same visibility adjustments to my other elevations. Is there a way I can save that view as a template and apply to other elevations, or do I instead need to create a view template, make all the adjustments to that template, then apply the template to the elevations?
3 REPLIES 3
tonkata
in reply to: tonkata
Never mind.... Just worked it out 😄
LisaDrago
Good to hear!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Discussion_Admin
Moved:
We moved your reply to its own topic in the Autodesk Revit Architecture forum.
