Revit Architecture
Distinguished Contributor
ennujozlagam
Message 1 of 7 (431 Views)
Vanity Top Materials
431 Views, 6 Replies
08-01-2011 02:14 AM
Hi Guys,
Maybe you could help with this. I tried to create a vanity top ( for my toilet) using  Model in place - Sweep profiles and assigned materials finished but it didnt showed up. is this can be done? or is there any easiest way to do a vanity top and can apply materials? Please find enclosed.
Thank you,
cbcarch
Message 2 of 7 (395 Views)
Re: Vanity Top Materials
08-02-2011 07:46 AM in reply to: ennujozlagam
Instead of modeling it in-place:
Use a Casework --Countertop Family for this. There should be one that comes with Revit out of the box, with parameters
for length, width, height, counte thickness, and Materials.
Load it into your project and then specify the Materials. You should even be able to assign separate Materials for the countertop and the backsplash, if needed.
cheers
Cliff B. Collins
Registered Architect/BIM Specialist
Autodesk Revit Expert Elite
ennujozlagam
Message 3 of 7 (365 Views)
08-03-2011 05:40 PM in reply to: cbcarch
I tried to look for this casework-counter top family but i cant find it. Do you know where it is?
ccollins
Message 4 of 7 (359 Views)
08-04-2011 05:39 AM in reply to: ennujozlagam
see attached.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
ccollins
Message 5 of 7 (353 Views)
08-04-2011 08:48 AM in reply to: ccollins
one more step.
see attached.
Cliff B. Collins
St. Louis, MO
ennujozlagam
Message 6 of 7 (338 Views)
08-04-2011 05:27 PM in reply to: ccollins
Hi Cliff,
Thank you very much for your help. Appreciated. Can i ask you again. I have to draw in Revit Steel staircase which means all the riser, steps and even landing are in steel profile, But i really dont know how and where to start? maybe if you could help with this?
Thank you and God Bless..
ccollins
Message 7 of 7 (327 Views)
08-05-2011 06:09 AM in reply to: ennujozlagam
Glad it worked.
For the steel stairs, try using Help in Revit for creating stairs--this should be a good place to begin.
If you then have trouble or more detailed questions, start a new thread on the forum.
Hint: Revit will create your stairs and railings automatically. You select the stair tool, draw the run(s) in plan,
specify which Levels the stair begins and ends at, click finish and it is done. That said, there are some problems
with the stair and railing tools, most of which can be overcome with tricky workarounds. But if it is a basic stair,
you should be able to create it quickly and effectively.
cheers
Cliff B. Collins
St. Louis, MO
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
