Using Velux imports
3 REPLIES 3
SimonJones5828
584 Views, 3 Replies
Using Velux imports
I am a new revit user and have downloaded Velux rfa, but when I place in roof, it appears to have shutter/blind closed.  This means when I create 3d view from inside or outside and then render, no light passes through or reflects on glass.  Does anyone know how to make the Velux perform more like the standard library roof window?  How to get rid of blinds/shutters?
Cheers
3 REPLIES 3
More information required. Can you attach the rfa family file.  What url did you download it from ?
Thanks for this. Here is URL
http://www.velux.co.uk/professionals/architects/tools/3dproduct.aspx
and attached is 1 of their .rfa downloads
You can modify the family by double clicking on it from the project or by opening it directly.
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
