Walls already have a "Cost" Parameter built in. If you'd like, you can interpret this as a "Cost/SF" and simply schedule it...
If you now want to calculate a total cost based on wall are, you can add a calculated value to your schedule... the trick here is to make sure your units match. So since the Cost paramter in the wall is a "Number" parameter (unitless), and area as a unit of Square Feet, you need to cancel out the Square Feet in the formula.
Note that "Total Cost equals Cost times (Area divided by 1 foot times 1 foot)" . The 1 foot times 1 foot nullifies the Square Feet of the Area parameter so that the entire equation is unitless, allowing for virtually any value to be calculated...
I've attached the project as well.
Steve Burri
Autodesk, Inc
Client Support Manager - Revit
"sandovala" wrote in message news:4094937.1097691639504.JavaMail.jive@jiveforum1.autodesk.com...
> Does anybody know of how to use formulas in Revit, for example, if I wanted to extablish a price per square foot, for a wall, or floor. How do I do it so that Revit recognizes it in the schedule. Thanks
Attachment not added (too many attachments): "Image2.gif"
Attachment not added (too many attachments): "Image4.gif"
Attachment not added (too many attachments): "Project1.rvt"
