Using Apple computer for Revit Architecture program.
2 REPLIES 2
ferpc
1128 Views, 2 Replies
Could you tell me if an Apple computer will perform as good as any other good PC
for using the Revit Architecture 2010 program or AutoCAD 2010?
Are there any inconviniences or possible problems using Apple?
Do you think is better not to experiment and buy a good PC system instead of Apple?
Thanks in advance.
Fernando
2 REPLIES 2
bt1138
in reply to: ferpc
When you consider how much more expensive Apple PC's are, it does not make sense to me to go that way unless you have a compelling reason to be using apple.
And the hassle factor of using bootcamp or whatever, what is the benefit? In order to use bootcamp, I think you need to go buy a shrinkwrap copy of windows, that's another $200-$300 retail.
in reply to: ferpc
Check out the following blog post:
http://aectechtalk.wordpress.com/2009/07/21/autodesk-supports-mac-users/
Doug
"ferpc" wrote in message news:6237592@discussion.autodesk.com...
good PC
Apple?
Thanks in advance.
Fernando
Rail Community
