What is the source of the assembly codes built into Revit? I'm familar with uniformat but not to the level used in Revit. For example I was aware the B1010 was floor construction, but did not know that B1010310 was the code for cast in place beams.
CSIs page on uniformat mentions that a new version is "on the way"
http://www.csinet.org/s_csi/sec.asp?TRACKID=&CID=1379&DID=11342
Did autodesk get a preliminary copy of the new Uniformat? Where did these extended codes come from. Other then copying all the codes from Revit's "Choose Assembly code" window is there a reference somewhere that I can use to find all the potential Uniformat codes?
