Having another mind-block.
I've setup a family for aluminium glazed doorset for use in Curtain Walling. It works fine, and adapts to suit opening size with equal leaf widths.
But, how can I create a wider leaf for one of the doors ?
I would like to setup a parameter in the family for a 'Master Door Leaf Width' (typically set at 1m) and a yes/no for "Equal Door Leafs".
So
If "Equal Door Leafs" = yes - the standard setup works.
If "Equal Door Leafs" = no - then the left leaf defaults to the "Master Door Leaf Width"
The trouble I'm having is that you don't appear to be able to drive the total door width from family parameters - as it is set by the curtain walling grid on placement.
I had thought to create a reporting instance parameter for the total width - then use a formula that if door leafs are equal leaf 1 = leaf 2 = total door width/2.
Trouble is it won't let me use a reported value in the formula, so I'm kinda stuck on how to get this to work.
Any ideas ?
Many thanks,
Martin
Having written the post - I realised that I could use a Visibility switch to alternate between Equal Leafs or preset unequal ones - but it feels like a bit of a cheat - there must be a more elegant solution that drives the width of each leaf via forumlae ?
Solved by Alfredo_Medina. Go to Solution.
Thanks Alfredo,
It won't let me delete the EQUAL dims (even after unpinning the central ref plane) - I can make them Unequal - but it then won't let me add a further dim as it would over-constrain.
I don't see any problem deleting the equal/equal and/or unpinning the reference plane. Which template are you using?
Thanks Alfredo, got it working.
bypassed not being able to delete the 'EQ' dim - by creating a new unused ref plane and fixing the EQ dim to that instead of the ref plane that actually drives the door leafs.
Seems to work a treat now, bottom one is when 'Equal Door Leafs' = No, Top when Yes - Master door leaf set by Type Parameter.
Many Thanks Alfredo,
All the best,
Martin
Template used was "Metric Door - Curtain Wall"
Unpinning was OK - it just would let me delete the dim, got it working though without deleting it.
Martin
