Hi Guys.
My Revit model is 100% made up of Linked models (about 10) as we purely use it for documentation purposes. We have floor plans and in some of them we need to show an Underlayed Ceiling Plan. I realise that setting up "Underlay = Level X" and "Underlay Orientation = Reflected Ceiling Plan" doesn't work.
Anyone knows how this could be solved. How can I get an Underlay Plan to show up when my model is purely linked models.
You can do the following steps to see the Linked RCP as underlay:
After linking the file go to visibility settings > Revit Links > Display Settings > Make it Custom > Then go to the visibility settings and on the ceiling categoty from model categories.
Unfortunately im pretty sure this cant be done.
There are a couple of "workarounds" but none are overly efficent
If you are using the 3rd method, you will be able to snap the RCP view to the center of the floor plan view on the sheet easily. You could always use a "Guide grid" if you wanted (see Paul Aubins post about Guide grids, it is brilliant http://paulaubin.com/blog/revit-guide-grids/ )
Just FYI, when i say "master" file, i mean the file with all your linked models in 🙂
Hope this helps
You can upvote this issue in the official Revit Ideas feedback forum, maybe it will get some attention:
http://forums.autodesk.com/t5/revit-ideas/underlay-and-linked-files/idi-p/6379628
