Revit Architecture
LisaDrago
Message 1 of 9 (480 Views)
Unable to share Shared Parameter txt file
480 Views, 8 Replies
02-04-2013 08:40 AM
Okay - I have been making and sharing shared parameter files for years... For some reason today a co-worker's shared parameter file is invalid or could not be read - image attached...
We have run a couple of tests - I can create one on my computer and send to her without any issues... Any that she creates and sends to me - is invalid... WHY???
I made sure she has all the service packs and all that - so I am really at a loss..
Any ideas?
I will attach one of the test.txt files..
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
CADastrophe
Message 2 of 9 (477 Views)
Re: Unable to share Shared Parameter txt file
02-04-2013 08:55 AM in reply to: LisaDrago
Are both you and your co-worker running the same version of Revit? Was the Shared Parameter file added to with a newer version of Revit? If a Shared Parameter was added to the file as a type that did not exist prior to that release, the file will be reported as 'invalid' by previous versions.
LisaDrago
Message 3 of 9 (472 Views)
02-04-2013 09:03 AM in reply to: CADastrophe
Yes - we are on the same version. We are both on 2013... That is why the invalid statement is baffling me...
LD
CADastrophe
Message 4 of 9 (464 Views)
02-04-2013 09:23 AM in reply to: LisaDrago
The problem appears to be with the file itself - I was unable to directly link your file, but I could Copy/Paste that exact text into a new .txt file and it worked. I even tried copy/pasting the contents my shared parameter file (which I know works) over the text in yours, and it still returned the error. I, unfortunately, do not know of a solution to this aside from attempting a reinstall. Perhaps there is an add-on that could be inadvertently causing this? Do you have any installed that your co-worker does not?
LisaDrago
Message 5 of 9 (451 Views)
02-04-2013 09:48 AM in reply to: CADastrophe
Sure enought that worked!
That is really odd though... will have to consider reinstalling.
I have a lot of the extensions from the subscription center installed and an FM:smileyfrustrated:ystems... She does not have any.
Thanks for your help!
LD
Message 6 of 9 (447 Views)
02-04-2013 09:51 AM in reply to: LisaDrago
Did you check the .txt file encoding?
LisaDrago
Message 7 of 9 (441 Views)
02-04-2013 10:03 AM in reply to: dhurtubise
How do you do that?
LD
Message 8 of 9 (417 Views)
02-05-2013 12:33 AM in reply to: LisaDrago
Save as and look at the encoding
New Member
Message 9 of 9 (114 Views)
12-10-2013 10:43 AM in reply to: dhurtubise
What should the encoding setting be?
I am having the same issue as LisaDrago...same exact error. Also tried to copy/paste into a new .txt but that did not work either.
See attached resultant .txt files.
Thanks so much for the advice.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
