Hi there
Basic question - when you have selected a line using 'pick lines', is it possible to unpick that line (if you have picked the wrong line for example)?
Many thanks
Marty
Solved by ameadows. Go to Solution.
No, not that I know of. You will just have to delete the incorrect line manually.
Ancient question but no answer... I use 'Ctrl Z' to unpick the last line selected or 'delete' key for previously picked lines (it changes the selection arrow to a selection arrow with a cross)
