How do you un-join walls so you can move one selection set without impacting the other?
Solved by constantin.stroescu. Go to Solution.
click on the wall to select it....now Right click on the Drag Wall Point > Disallow Join...now you can move it freely
I completed my drawing and now my outside walls are longer than needed. How do I move them and keep the dimensions inside the house
Any suggestions on how to do his horizontally where you have 2 walls that meet but only want to meet on centres not exterior faces
