UNION Parametric
2 REPLIES 2
GHASEM_ARIYANI
371 Views, 2 Replies
UNION Parametric
hi
I want Parameter UNION For my definition of family
Can you help me?
I Attached the in family(Saved Revit 2014)
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
CoreyDaun
in reply to: GHASEM_ARIYANI
Unfortunately, since you have built your Family by designing one segment and creating a parametric array, I don't think you'll be able to remove those seam lines (since you cannot join them). The Linework tool won't even be of any help here.
I believe that the only way that you can escape the seam lines would be to create a long length of your pattern and use a Void Extrusion and a dimensional constraint to "cut" the continuous pattern to the desired length. Continue the Sweep Paths for how ever many segments needed and created an array for the spheres (not the 'half-sphere' end pieces). Create an Integer parameter intended to determine the number of segments which will drive the overall length Parameter. (i.e. = Number of Segments * Length of Segment)
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
GHASEM_ARIYANI
in reply to: CoreyDaun
Hi Thanks for your answer. Commands that you I did and try But unfortunately Failed, I wish I could do on a simple model of attachment. Thanks .
