Revit Architecture
Message 1 of 7 (205 Views)
Accepted Solution
Two Floor Plans on a Work SET
205 Views, 6 Replies
06-25-2012 06:16 PM
Good day...to all masters here in Autodesk...
I have a situation today while using revit...in which we just encountered just today...
I already laid out floor plans for our project...but that is only architectural...
then we are currently on worksets...
I was wondering how we could pull this off...
cause first we laid out ARCHITECTURAL floor PLANS with FINISHES...
then we wanted to create the same Floor plans but has no FINISHES and it is referred to as a concrete body plan...
how can i draw two drawings at the same time if there are already one floor plan drawn at the same project...
does design OPTIONS works even in worksets?...we are currently working on a big project and the procedure is badly needed for us...
if so..can somebody help me how to do the procedure thank you...very much
parveen.revit
Message 2 of 7 (196 Views)
Re: Two Floor Plans on a Work SET
06-26-2012 12:24 AM in reply to: KOAsgpp
you can easily do it by just creating a duplicate view and set the visibility right (turn off the finished and unwanted elements).
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Message 3 of 7 (176 Views)
06-27-2012 06:33 PM in reply to: KOAsgpp
is there a different way of performing without turning off or this is only a work around?
thank you for the reply sir..: )
Message 4 of 7 (175 Views)
06-27-2012 06:39 PM in reply to: parveen.revit
how do i turn off the finishes?
when on a duplicated view without getting the main plan turned off as well...
attached here is the screenshot...for the said problem...
because i know that if i duplicate whatever happens with the other one happens to the original one...
i wish to eliminate this...: ) if there is a way..please teach me how or guide me through thank you.. :smileyhappy:
*Expert Elite*
Alfredo_Medina
Message 5 of 7 (162 Views)
06-28-2012 04:20 AM in reply to: KOAsgpp
You need to start a new standard in your office:  Model the finish walls with separate, thin, wall types.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
*Expert Elite*
Alfredo_Medina
Message 6 of 7 (152 Views)
06-28-2012 07:02 AM in reply to: Alfredo_Medina
Another option is to select all the walls and do "Create parts". That will allow you to select layers individually and turn them off.
In summary,
  • Option 1: modeling walls with separate wall types, from scratch.
  • Option 2: using parts.
It cannot be done simply with visibility graphics settings.
Message 7 of 7 (141 Views)
06-28-2012 05:27 PM in reply to: Alfredo_Medina
ohhhh i see...thanks..i guess that is what i needed to know..: )
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
