This does nothing for me. Typing SO turns the snaps on/off, and SS overrides the snap... but when rotating something (text in this case), it snaps to a 45-degree angle no matter what. Seriously. No. Matter. What. I'm trying to place text along a property line that is only a couple degrees off a 45... so I guess I just let it look like I didn't know how to use the Rotate tool. Thanks Revit.
You can use the rotate tool and type in the rotation angle to get a specific angle for the text along the property line.
You can also trun off "Angular Dimension Snap Increments" in the snaps dialog to help when placing elemnts at differnt angles.
@loboarch wrote:You can use the rotate tool and type in the rotation angle to get a specific angle for the text along the property line.
I am having the opposite problem. I am in Revit 2015 which we haven't used much - skipped right to 2016. I can't get pipes to draw at typical angle increments. I keep getting pipes at 90.023 and 30.174 etc. which plays havoc with connections. I am guessing there is a setting to restrict angular constraints, but I can't find it. I can constrain fittings, but not the straight sections. I haven't seen this problem in other versions, but due to collaboration with outside firms, I have to stick wit 2015 for this project. Any thoughts?
