I have created a new custom component that is basically a block which has a "tab" on each surface. I would like to be able to turn ON/OFF the various tabs in the Properties (or Type Properties) Dialogue Box for each of these components on a component by component basis. Is it possible for me to create a custom section within the Properties Dialogue Box which allows me to turn ON/OFF each of these tabs as I like?
Ideally, there would be a list in the Properties Box like this
Top Tab:
Bottom Tab:
Right Tab:
Left Tab:
For each Tab, I would check or uncheck a box, or say ON or OFF and the object would display or not display in the model.
Any help is appreciated.
Not sure I folow you here, but if you by "tab" means a new catergory to sort the parameters by, then no.
If you just wana create the paarameters, "Top Tab:", "Bottom Tab:" etc., and sort them under i.e. "Graphics" you create those parameters as "Yes/No" parameters, and asign the parameter to the tab objects.
(select geometry > properties > visibility > click the tiny square box > assign the parameter you just created)
KM,
You do understand me correctly. It sounds like I need to create a Family Type for each possible variation of block. I had wanted to give each tab a name and turn them ON/OFF on a block-by-block basis and create a schedule of which blocks have which tabs turned ON.
Thanks.
You can do that, but you need to make the Yes/No parameters INSTANCE based to turn them on/offa block-by-block basis.
Besides the parameters also need to be SHARED parameters, if you wanna use them in schedules.
