Can this be done?
Turn off sheets that are not done (but I still want the sheet layout setup in the project browser.)
So that hey do not show up in the automatic index on the cover sheet.
Solved by duncan.lithgow. Go to Solution.
You could add a project parameter to sheets for "complete" or "not complete" then the sheet index could look and filter based on that parameter. Then make that column hidden in the sheet list.
If you just want to stop it showing up in your index you can remove the check from 'Appears in Sheet List'. This will hide it in a Schedule made with the Sheet List tool.
