True radius curtain wall
6 REPLIES 6
772 Views, 6 Replies
Is is possible for REVIT to create a true radius curtain wall? When I create a curved curtain wall it ends up being a segmented curtain wall instead.
6 REPLIES 6
cbcarch
Using the curtainwall tool, this is not possible.
You could model a family with a true radius.
FWIW
I must ask, does the client really want to pay for bent glass?
That is VERY expensive. Which is why most curved curtainwalls are segmented.
cheers......
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Thanks for the advice.....and yes, the client...."thinks" they want radius glass. I asked what happens when after installed, on say the 10th floor...a lite of glass is broken???? Mine is not to reason why...
Alfredo_Medina
Wait until your clients see the first estimates for the curtain wall with bent glass. They are going to like the segmented curtain wall a lot more than now.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
in reply to: Alfredo_Medina
We have some Chinese clients with deep pockets who want curved glass and mullions, unfortunatly I can't figure it out in Revit.  Seems like all the posts about curved glass give your response about cost and no solutions.  If anyone can point me in the right direction it would be appreciated.
Alfredo_Medina
Actually, this is possible, especially if the curve is one direction only, like in a cylinder or similar. You need to create a curved panel, with a parameter that controls a point, which controls the curvature of the panel.  You need to make some calculations to relate this parameter with the radius of the curtain wall.
bms953
take a look to this post :  https://dddmodeling.wordpress.com/2016/10/28/curve-mullion-with-in-revit/
Behzad Meskini
Competitor in World skills Competition 2005 Finland (Mech,Eng,CADD)
Member of Iranian Elite Foundation
Autodesk Certified Professional-AutoCAD
Autodesk Certified Professional-Inventor Pro
Autodesk Certified Professional-3ds Max
Autodesk Certified Professional-Revit Architecture
Autodesk Certified Professional-Revit Structure
Autodesk Certified Professional-Revit MEP
DS CATIA Certified V5 Mechanical Surface Designer Specialist
DS CATIA Certified V5 Associate - Part Design
DS CATIA Certified V5 Associate - Surface Design
DS Solidworks-CSWP-Mechanical Design Professional
DS Solidworks-CSWA-Advanced Sheet Metal Professional
DS Solidworks-CSWA-Advanced Weldments Professional
DS Solidworks-CSWA-Advanced Surface Professional
DS Solidworks-CSWA-Advanced Drawing Professional
