Hey everyone,
I'm having a bit of trouble installing Revit 2014. I'm using a student license.
AutoCAD installed without any touble, but I've attempted Revit a number of times with no luck.
The installation seems to travel smoothly until it's up to '0 of 14 remaining', at which point it reverts back to installing the Language Pack and other packages and will read as '3 or 4 of 14 remaining'. The file claims to be 2.68Gb of 2.68Gb downloaded.
Has anyone else had similar trouble? The installation will finally wrap up, but Revit 2014 and the Material Library will read as 'Failed'.
I hope I'm not spamming here and posting in the wrong section, but I've had no luck otherwise!
Cheers,
Mark
Hi Mark
First of all welcome to the community. I hope I can assist you with this issue.
Have you had any other Autodesk Products installed on that machine and what was the version? Are you installing the Building Design Suite or AutoCAD and Revit as seperate packages? Sounds like seperate packages.
Hi Jo,
I recently bought a new laptop, and have so far only installed AutoCAD 2014 as a separate package.
I was attempting to install Revit 2014 but have had no luck.
Any suggestions?
