Transparent model elements in shaded view
3 REPLIES 3
BIMAbhi
3066 Views, 3 Replies
In Revit 2013 - Some elements are displaying as transparent in the 3D Shaded view. All the glass elements are showing through solid parts of the model in 3D shaded view. Please see the attached image. Are there any settings to fix this issue?
Thanks & Regards
BIMAbhi
3 REPLIES 3
in reply to: BIMAbhi
Hi, we have on some (not on all) computers the same problem and switch of the hardware acceleration. You could also try to reduce tre transparency of your material to 0, this should work also.
rosskirby
Update your video card drivers and make sure you have all Revit service releases installed.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Joe.Charpentier
Ross is right- this is an issue with older display drivers.
Details here:
http://revitclinic.typepad.com/my_weblog/2012/04/glazing-appears-through-walls-in-revit-2013.html
Joe
