Transparency in floorplan?
5 REPLIES 5
folkeh
599 Views, 5 Replies
Hi
I have just installed update 1 + 2 in hopes that the problem with transparency in floorplan would have been corrected, but sadly it hasen´t been (!).
We rely very much on this function for showing for instance things behind ceillings.
The print raster function is a no-go, because we also need to export plans to DWG files in many cases.
Best regards
Jakob Hansen (Denmark)
5 REPLIES 5
Alfredo_Medina
in reply to: folkeh
Can you please post one or two images describing the current problem and the desired result?
I have not heard before about a problem with "transparency in floorplan". What do you mean by that?
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
folkeh
in reply to: Alfredo_Medina
Here for test purpose I have made a duct over the ceilling and made the ceilling transparent.
As you can see the duct disapere in the PDF, but only when the entire duct is behind the ceilling!?
Info: Ceillingplan.
        Ceilling hight: 2800mm
        Duct hight: 3000mm
This is clearly a bug that came with Revit 2013. There was no problems prior to 2013!
Screenshot in Revit:
PDF vector print:
Alfredo_Medina
in reply to: folkeh
Can you post that sample .rvt file?
folkeh
Hi
There is really not that much to share, it´s a very basic setup: four walls and a ceilling.
As said before, there was no problem in Revit 2012, so this post is more a cry to Autodesk for an update that actually addresses this issue.
Best regards.
Alfredo_Medina
in reply to: folkeh
Better than posting a cry, it is more useful to post a file, so that somebody can try to detect what is going on.
