When i install transom windows Sill height =7'1 View range is 4' and the transom windows dont show up. If i increase the view range to include the windows my door head height dis appears. How do you fix this?
Solved by cbcarch. Go to Solution.
Please find the attached file for your help. Floor to Floor height is 10'-0".
If it is help to solve your problem then marked as "Solved" and send me "Kudos" Also.
Thanks & regards,
Subhradeep Sen
Kolkata
india
You can also use a Plan Region. View>Plan Views>Plan Region.
Place Plan Region around transom area; highlight/select it; then under Properties adjust View Range cut plane so it shows the transon window.
This allows the main floor plan View Range to remain at 4', and shows the transom above.
