At work i am working on a project where there has been added a shared parameter under identity data in the "room" properties. In this extra identity data column, the room name has been added. When the engineers link our model into revit structure, they dont see the room name because they dont have this shared parameter. I exported this shared parameter and they added it to thier revit, but the room names stilll doesnt show up. The problem here is that there are about 300 rooms in this buillding so deleting the room name from the added parameter and writing it in the "room name" property willl take way to long time. Can anyone help mere here? it woulld save me alot of time
-Rasmus
Solved by parveen.revit. Go to Solution.
this issue is related to link revit model.
you can check the link file properties.
