Total area of ​​the same material
6 REPLIES 6
GHASEM_ARIYANI
1142 Views, 6 Replies
Hi
How can I calculate the total area of material similar to a project.
For example, ceramics, In my project I want to calculate the total area of ceramics, but I do not want a separate display
Instead, I have only one row show the total area of ceramics.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
6 REPLIES 6
L.Maas
in reply to: GHASEM_ARIYANI
I would assign a parameter field (or add a project parameter) in the materials to accomplish what you want.
For example use The "Comments" field in the materials and use that to group materials.
Name all your different ceramic types "ceramic" in the comments field. All different plastics you could name "plastic" in the comment field. In your schedule add the "Materials:Comments" field and sort on that. With "itemize every instance" deselected you can now totalize all your different material groups.
If you have lots of materials this can be quite some work.
Louis
Please mention Revit version, especially when uploading Revit files.
GHASEM_ARIYANI
in reply to: L.Maas
Thanks for your answer.
I've used Paint Tool,Attach file in my above post.
The way you said I did not give the correct result.
L.Maas
Attached your modified project.
I used both methods (used an existing parameter and added  a parameter)
See the two material take-offs
I hope this is what you need
Louis
GHASEM_ARIYANI
in reply to: L.Maas
hi
Thank you
You are right
GHASEM_ARIYANI
in reply to: L.Maas
Hi
I did this in a project pretty great ,But material Field Area Empty Displays.
I've uploaded the file on the link below
Please check Where is my problem?
https://grabcad.com/library/advanced-modeling-project-in-revit-architecture-2
L.Maas
Sorry for bad formatting. At moment I experience problems with this forum. In the schedule properties. Under formatting check that for field "Material:Area" "Calculate Totals" is selected.
Louis
