Toposurface from 'import instance'
4 REPLIES 4
691 Views, 4 Replies
In Revit 9.0 I easily create a toposurface from the 'import instance' function. In Revit 9.1 however, I follow exactly the same steps, but it is impossible to create the toposurface, as the imported drawing does not want to highlight (or do anything when you move the cursor over it) once I have selected the 'import instance' function. IE i follow the Help file step by step and get a result in 9.0 but no result in 9.1...What's going on, does anyone know?
4 REPLIES 4
I am guessing that you imported your DWG into the current view when importing it. I had the same problem and deduced that the factory made a change that you now have to import the DWG into every view inorder to select it.
Mel Persin, AIA
I had the exact same problem! I tried importing directly into the sketch mode but it still doesn't work - any suggestions?
When you try to use an imported DWG to create a
toposurface you need to make sure when importing you do NOT have the "current
view only" check box checked.
Jeff Hanson
Autodesk - AEC User Experience
Team
Manchester, NH
I
This is what i call a very usefull answer, thank you very much.
